Old 08-05-2015, 06:36 PM
CLE-0129 CLE-0129 is offline
Default Spindle replacement question
Well now that I have my belt situation under control my next problem is the middle deck spindle. It looks like half of it is broken off. Previous owner had a couple small nails in it to make up the difference on where it was broken. I can't seem to find the replacement spindle for it. The part number I have come up with is 477-436-R92. Looks like I might need a beer pulley as well but I might be able to make this one work. What do you guys think?
Thanks,
Ben
Old 08-05-2015, 08:10 PM
sawdustdad's Avatar
looks like the keyway broke off the shaft. I'd pull the shaft, take it to a machine shop to have it weld repaired and a new keyway cut in it on the other side. Take him the pulley too so he knows what size keyway to cut.
Old 08-05-2015, 09:20 PM
So I can't just buy a replacement shaft then? Maybe I will look into doing some welding on it with my welder. I still have the keyway so I can build it up around that.
Old 08-05-2015, 09:52 PM
If you get too much heat into it, it will collapse the threads.
Make sure you get the key straight so you don't ruin the pulley.
Jeff
Old 08-05-2015, 10:19 PM
Guess I will see what I can come up with. Kinda surprised there aren't replacements you can buy.
Old 08-05-2015, 10:24 PM
Is this the spindle with the "hat" on it? I make various parts but getting the hat square to shaft is a major PITA
Old 08-05-2015, 10:30 PM
There are replacements,new or used,the number you list is not correct though.
Try our sponsor's on top of the page,or put a ad in the wanted section with the deck size and serial # if you have it on there still
