Old 08-22-2015, 09:26 PM
Phil21502 Phil21502 is offline
Default 127 steering issue
On my newly acquired 127 it steers way sharper to the right compared to left. Can this be fixed my adjusting the draglink length? IF so should I make it longer or shorter? Also I saw a video on you tube where a fellar drilled another hole on the steering arm to make it steer sharper. Does this work? If so what size drill bit is needed? Thanks for any help
Old 08-22-2015, 09:38 PM
Turn the steering wheel all the way to (R or L). Now go the opposite way and count the number of turns. Now go back 1/2 of that number (usually 1-1/2). Disconnect the drag link. Set the front wheels to straight. Adjust the drag link as to hook back up to the steering pitman. Whala, you are done.
Old 08-22-2015, 09:40 PM
rdeyoe rdeyoe is offline
I have a new to me 1450 that does the exact opposite. Super sharp to the left, but twice the circle diameter going right. I'll be keeping an eye on this thread...maybe some solutions would work on mine too.
edit: well shoot Roland. You must've been typing at the same time I was. Hit submit and your answer was already there. I'm going to try that too....
Yes it can be adjusted.
Yes, you need to adjust the length of the drag link from the steering box to the spindle. Look at it.... should be pretty easy to figure out if it needs to be longer of shorter.
Old 08-22-2015, 09:51 PM
timbo2's Avatar
timbo2 timbo2 is offline
Yep just see how the rod affects the turn and adjust from there. give the ball joint a turn or 2 and the check. 2 or maybe 3 adjustments and you're done.
I like a slightly tighter left hand turn since that's the trim side of mower decks.
- Tim
Old 08-22-2015, 10:14 PM
Thanks guys in my head tonight I thought the draglink would need to be shorter. I took it apart and the draglink was already as short as possible so I put it back together. Maybe I should try making it longer?
Old 08-22-2015, 10:18 PM
timbo2's Avatar
if both ball joints are tightened all the way then something is wrong.
Make it longer. what's the worst that could happen?
- Tim
Old 08-22-2015, 10:21 PM
I'm thinking yours would need to be longer too Phil. Mine must be too long. It pushes so far going left that the tire will actually contact the drag link. I must have to shorten mine. Think i'm going to use Roland's technique above. Looks like the right way....
Old 08-22-2015, 10:31 PM
Yeah I'm gonna try it after work 2moro. Thanks guys.
Old 08-22-2015, 10:34 PM
Terry C's Avatar
Terry C Terry C is offline
Now that's taking mowing pretty serious, customizing the steering.
NASCAR drivers mowers all are that way
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
