Old 08-23-2015, 07:20 PM
Default I finally installed the float button on my 125 ....
and it's amazing how nice the float feature works on my 125 with the 42" cast iron end mower.
Back in '03 when I purchased the 125, the button for the lift handle was missing so I drilled and tapped a piece of 1/2" round bar. That worked for setting it in a notch but since it didn't have the correct cutout plus the push button on the handle itself was broken, no float.
I made the correct handle button ( thank to Lew for the original to copy ) and installed a factory float button in the handle.
The lawn looks even better now
Old 08-23-2015, 07:44 PM
looks good as always Jeff, if i were in need of one what would it cost?
Old 08-23-2015, 07:50 PM
Probably around $18. The undercut for the push button latch is a real to cut.
Old 08-23-2015, 08:11 PM
Can you make the little lock button too? The 125 I gave my bro was missing the little button. Would be cool to get him one.....
Old 08-23-2015, 08:16 PM
Sheetmetal for the center section. But it is available from the dealer ( around $24 )
edit
Cub Cadet IH-401449-R1
Lock Assy, Release Rod
Old 08-23-2015, 08:20 PM
I'll check again on that. I thought I had looked and it wasn't available. Maybe I just assumed. That was a while back.
Nice work as always!
Old 08-24-2015, 12:00 AM
Berwil's Avatar
Berwil Berwil is offline
Nice job Jeff!
I finally made a wire bail to lock float on my O earlier this summer. It's nice when the little jobs make a big difference!
Bill
