Old 09-11-2015, 07:54 AM
KentuckyCub KentuckyCub is offline
Default 124 cub?
I'm pretty new to the cub game. I bought an 1810 and loved it. Then blew it up. I have been on the lookout for a parts tractor, I found this 124. Will my 46" deck work on it? Any advice on the 124? For $300 it seems like a bargain. Runs fine he says.
Old 09-11-2015, 08:38 AM
I don't think so.
The correct mower deck would be the Quick Attach 38", 42" or 48" mower decks.
Old 09-11-2015, 08:59 AM
johns cubs's Avatar
johns cubs johns cubs is offline
Looks like it was taken care of. I have the 104 repowered with k301 and it is a little beast! I love it and would definately buy another for 300 especially with ag tires!
John
Old 09-11-2015, 10:00 AM
I'm torn here. My 1810 is perfect except the blown rod if that makes sense! But this is an interesting little tractor. I bought a zero turn for mowing. Would this do well moving trailers and hauling miscellaneous?
Old 09-11-2015, 10:24 AM
snoel's Avatar
snoel snoel is offline
Yes. Excellent for odd jobs.
Steve
Old 09-11-2015, 10:25 AM
Berwil's Avatar
Berwil Berwil is offline
For towing trailers and carts, the 124 will do just as well as your 1810. If you haven't physically looked at the 124, be aware the steering and clutch will most likely need work. This is more due to neglect and 40+ years of wear, not inferior design.
As far as the 1810, there are a few options that should make finding a replacement easier. You can repower with a vanguard or magnum or ch kohler out of a cub. I know of at least one member here that even has a k series kohler in a 10/11 series tractor.
The right answer is to buy the 124 and find a new engine for the 1810 and keep them both.
Welcome to the sickness.
Bill
Old 09-11-2015, 12:19 PM
Rmowl's Avatar
Rmowl Rmowl is offline
That's a nice 124. I bought mine from the original owners next door neighbor, with a no 2 cart and ez vac panels. I use it to mow an acre yard, no problems except spindle froze up in the axle. I wash it down after each time I mow, keep blades sharp, bearings greased, deck coated with Teflon spray. That's a good deal for $300
-Rick
IH 782
IH 126
CCC 1863
Old 09-11-2015, 01:39 PM
Here is a link for a re-power kit for the 1810-1812's
http://www.smallenginewarehouse.com/...tegory=1710970
Pretty much plug and play.
Old 09-11-2015, 05:10 PM
$1600???? No way. I can buy 3-4 Cubs for that!
Old 09-12-2015, 08:54 AM
budscub's Avatar
budscub budscub is offline
Default nice 124
Good morning Kentucky Cub,
Nice 124, I have a 125, same tractor but in a hydro. Nice little beast they are.
I also have a 1450 and 1650. I m just curious, as i am also in Ky. (Loretto) were about are you located? Have a great day.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
