Old 10-25-2015, 02:11 PM
thadscub's Avatar
thadscub thadscub is offline
Default New used trailer help
hi guys i have the change to get a free 4x6 utility trailer problem it has old 15 or 16 vintage truck or car tires on it from the 50'or60' need help if anyone knows what size tires would fit or what rims will fit
thanks thad
Old 10-25-2015, 02:47 PM
ford4150's Avatar
ford4150 ford4150 is offline
What size tires are on it now?
How many lug bolts/studs on the axle? What is the bolt circle diameter?
What is the back space of the wheel; distance from the mounting surface to the back edge of the rim?
What is the wheel offset; distance from the mounting surface to the center line of the wheel? This can be either a positive or negative value.
Does the trailer have fenders? If not, do you plan on adding them? The tires have to fit under the fenders.
Just a few of the things you must find out to get an answer to your question.
Old 10-25-2015, 02:53 PM
take the old tire to the dealer and they should be able to match something up for you.
Old 10-25-2015, 03:41 PM
from the 50' or 60'
Confusing....does this mean 50 or 60 feet.......or 1950 or 1960...?
Old 10-25-2015, 04:39 PM
JLM78 JLM78 is offline
If they are split rims don't use them
Old 10-26-2015, 01:23 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Not sure what's confusing. He states it's a 4x6 trailer.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 10-26-2015, 06:15 PM
rocker582special's Avatar
rocker582special rocker582special is offline
I agree with olds on this one. Take one of the tires to your nearest tire store and they should be able to find a match or an updated version of it.
Old 10-26-2015, 09:36 PM
mmzullo mmzullo is offline
5 lug? Measure center to center on 2 closes lugs and go to a trailer shop and tell them they can tell what you have from that spacing. But back then it could be 5x4.5 or 5x4 3/4 or 5x5 inch spacing. Unless you have a vw axle which I doubt.
I have a gauge at home but that wont do you any good.
