Old 05-15-2015, 04:48 PM
rdehli rdehli is offline
Default 122 clutch issues
Working on a 122 for a buddy of mine. Removed old clutch, installed new one with new bearing, teaser spring, drive shaft, and 800ib spring from Midwest super cup. Clutch will not engage. Worked ok before removed, but old clutch was weak.
Old 05-15-2015, 05:02 PM
with the motor moved forward the clutch cannot be turned, even with the clutch engaged and tractor in neutral the drive shaft cannot be turned , need some advice thnx in advance
also on the rear pressure plate is wanting to rub excessively on the the clutch engagement arm??? why? adjusting nut is all the way loose too.
Old 05-15-2015, 05:55 PM
Merk Merk is offline
Just a guess....
Looks like the throw out bearing is installed back words.
Project Uncle Dick
Cub Cadet 70
Old 05-15-2015, 06:41 PM
a few pics of the driveline
Old 05-15-2015, 07:05 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
the throwout arm rubs because you have the adjuster nut backed all the way off. adjust it in and it will pull it closer to the bearing.
Old 05-15-2015, 08:13 PM
When you adjust the nut in farther you cannot press the clutch more than 1/2 way down.
Old 05-15-2015, 08:20 PM
raytasch raytasch is offline
Is your brake mechanism free?
122 original, well used. Owned since 1972
2182 new to me. Refurbished and gave to my son.
Deere 4300 4WDA HST with FEL
Many old Ford tractors, all gone now
Couple old Ford trucks
Old 05-15-2015, 08:41 PM
im with merk, the throwout bearing is on backwards.
Old 05-15-2015, 08:59 PM
dvogtvpe's Avatar
no, you can see the shoulder of the throw out bearing facing the teaser so that's in correct.
Old 05-15-2015, 09:00 PM
dvogtvpe's Avatar
is the spring coil binding? did you adjust the brake correctly? that can hold back pedal travel
