Old 12-26-2017, 02:31 PM
Workingstiff Workingstiff is offline
Default 1200 snow removal
Hi,looking for opinions, about picking up a snowblower/snowthrower. Of the ones to fit my 1200, what is the most reliable,best built unit. I have about 200' of concrete driveway. We typically don't get dumped on but every few storms it lets loose. I have a blade and a 24" Ariens I use now. Its about the same time wise with either machine.
Thx Dan
190-364-100 45" Snowthrower (IH Design)
Haben Snowthrowers H42, H48, H48, H42, 353, 354
QA36A, QA42A Snowthrowers
Old 12-26-2017, 03:45 PM
The Haban H48 won't work on your QL. Neither will the 353/4. Only the H42.
QA42A is the most common and easy to find. ALL other options are not as common and can be hard to find. If you want a snowthrower, you may pick any of the models you listed (that fit) as there are basically no difference other than size.... with one exception. The 364 blower requires a specific adapter to run on a QL tractor. They weren't a common blower and finding the correct mounting parts is difficult on a perfect day. QA42A is your best bet.
That said, you will need a creeper on your 1200 to run a snowthrower/blower. Does it have one?
Old 12-26-2017, 03:46 PM
The QA36A or QA42A Snowthrowers were designed for the 1200.
Old 12-26-2017, 04:39 PM
Nope, no creeper. I read the first 20+ pages here about blowers/throwers. I saw lots had mentioned keeping it loaded to throw properly. My hopes were on typicals snows it would work better than I hoped . But if thats not the case than so be it. Is a creeper hydro only? If not difficult to install? Is it another gear set?
Old 12-26-2017, 06:19 PM
twoton twoton is offline
Originally Posted by Workingstiff View Post
.....Is it another gear set?
Yes, gives you high low range. Here's a picture that I stole from sawdustdad of one on his 1000;
http://www.onlycubcadets.net/forum/s...003#post312003
Old 12-26-2017, 08:24 PM
Here's my 125 ( hydro ) with a QA42 ( narrow frame version of the QA42A which is adjustable for both )
https://www.youtube.com/watch?v=tfWy8jbj_GY
Old 12-26-2017, 08:44 PM
Terry C's Avatar
Terry C Terry C is offline
Watch some snowblowing/throwing vids on YouTube. Watch how slow they have to go when the snow gets pretty deep. That’s why you want a creeper on a gear drive with a thrower. Or you have to ride the clutch a lot .
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-26-2017, 08:54 PM
Agreed. I had engine problems one year on my 125 and switched the QA-42 over to the 122 with a creeper.
While it worked well, there was a LOT of shifting required between gears and high and low range.
Let's just say it was an incentive to fix the K-301 for the 125.
And yes, you can bolt a QA implement onto a NF without the QA mounts.
Old 12-26-2017, 08:58 PM
Jeff posted one, but here's another.
https://www.youtube.com/watch?v=gqK5r10xKBc
(Sorry about the quality, it's an old cell phone video.) And that's a 18hp with a QA42A in snow about as hard and heavy as it gets. Can't go very fast when it's deep. I'll have to look and see if I have a video of the same tractor with the 450 blower on it.
Old 12-26-2017, 10:32 PM
yettrbomb yettrbomb is offline
My pops has a 450 on an 1811. Heavy piece but man does it work!
