I have a 1862 parts tractor that as you know has the power steering. Would the power steering from this work on my 1863? What all would need to be done to do the swap?
I did the PS swap from an 1864 to a 1641 so it's the same deal.
I used the Sunstrand hydro/differential, PS lines and lower steering column from the 1864. It's a simple bolt in. I don't think I forgot anything. You'll like the Sunstrand better than the Hydro-Gear. The Sunstrand is smoother and takes less effort to change ground speeds at at the handle. |
Thanks Mike I don't know the difference between the sunstrand and the hydro- gear can you enlighten me?
-Ryan
Using the Sunstrand lets you use the standard production hydraulic lines instead of having to custom make them. I've been told the Hydro Gear won't support PS but I don't know that. |
Thats more then I knew before. thank you. So I guess the hydro is the alum housing?
