Picked up a WH tractor with a johnson model 10 loader on it with intentions to move the loader to one of my 149's.
It is low on fluid and want to make sure I can use Hy-Tran to top it off. Thanks for the help! Randy
2 original cub cadets ![]() 1 100's 2 149's 1 73 1 2182 |
What is low on fluid, the loader, the WH or the 149?
i just use light hydraulic fluid on my kwik-way if thats what you mean but in winter that seems thick could use trans fluid in winter hy-tran would be kind of expensive in the loader
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
Sorry, yes the loader has a tiny leak.
Thanks, RAndy
Since I don't know exactly what has been used in it, should I drain the old and put all new? First loader and want to make sure I use the right stuff. Randy
![]() If I was you, I drain the system, repair the leak , install a inline filter (If you don't already have one) and fill back the system with standard or synthetic hydraulic fluid (Budget wise)
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
All good advice, one thing I might add is TSC sells a 505 fluid. it is pretty thick and gives problems in cooler temps so I would stick with a lighter weight fluid.
good luck! |
Randy Littrell, this is from the Johnson Loader manual...........
Thank you all for the help, I believe a can get it from here now!!
![]() Randy
