Old 03-29-2012, 10:59 PM
silverthornethan silverthornethan is offline
Default Battery
How long whould a battery last running the motor and fuel pump without a generator? I'm only doing this because I don't wanna build a guard for pulley. Thanks guys
Old 03-30-2012, 08:39 AM
Well that is dependent on what you are talking about.
If the engine has a magneto and gravity flow fuel, it will run till it runs out of fuel, or has a mechanical problem
if it has a points/coil system, till the battery runs down and that is dependent on how large the battery is.
I could go on and on but I think you get the picture.
Old 03-30-2012, 12:34 PM
It is a points and coil system. I was wondering how many passes I could get out of a battery before it would need recharged?
Old 04-05-2012, 09:04 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
about 13 or so years ago I built a stocker with no charging system and a ring gear starter, biggest draw it starting it. I had a good quality L&G battery in it and never questioned weather or not could make a run or not. I did try to keep the number of startups to a minimum.charged it the moring or night before an event. in my PS/SS I run a small motorcycle battery ,. it runs a holley pump and the ign. system and one other item. charge it at the start of a weekend .
Old 01-11-2016, 08:51 AM
bschmittling bschmittling is offline
Attachment 22987
Which motorcycle battery do you run? Any recommendations. I am looking for one for my puller.
Thanks
Old 01-11-2016, 11:43 AM
You guys may find this info useful, 16 volt batteries.
http://www.hotrod.com/how-to/interio...olt-batteries/
