Old 02-09-2016, 06:49 AM
cdlong's Avatar
cdlong cdlong is offline
Default Snow thrower Chute rotator
We got forcast for 4-8" of snow last night. I checked the tractor and snow thrower over and when to Lowe's for a 48" rod to make a handle for the rotator. Once installed, the chute didn't rotate. It had the shorter length gear on it. I got the gear off the QA-42, it's longer, and it rotates slighty. I can rotate the chute by turning the u-joint without the handle. Looks like the gear is cockeyed, but I don't see a way to adjust it. other than a BFH. What am I missing here?
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 02-09-2016, 07:03 AM
BFH....sounds like the remedy to me.
Old 02-09-2016, 10:47 AM
cdlong's Avatar
i thought the same thing, but that's my standard fix if duct tape don't work.
Papaw
Old 02-09-2016, 11:03 AM
It does look like the bracket is bent a little, ya might try bending it back with a big pair of pliers or a crescent wrench.
Old 02-09-2016, 12:38 PM
cdlong's Avatar
Thank you sir!
Papaw
Old 02-09-2016, 01:06 PM
Now take the rotator off the bracket and either hit or bend the mounting bracket with a wrench as mentioned.
otherwise you will break the rotator, if left on while bending.
They are thin die casting.
Be careful, you've been warned.
Old 02-09-2016, 01:15 PM
Exactly right, take the chute adjuster off first!
Old 02-09-2016, 04:59 PM
cdlong's Avatar
Will do! If it breaks, is it a Duct Tape fix?
Papaw
Old 02-09-2016, 09:16 PM
Old 02-10-2016, 05:55 AM
cdlong's Avatar
Got it for now. Took a Harbor Feight tarp clamp apart & cut it dowm for a shim.Now to buy one of those hi dollar u-joints.
Papaw
