Old 03-09-2016, 09:14 AM
Lane223 Lane223 is offline
Default 782 gas in engine head
We have an old 782 that there is gas leaking into the engine head, and last time we tried to start it it nearly caught on fire, shooting flames out of the carb. Any suggestions would be greatly appreciated.
Old 03-09-2016, 09:20 AM
First, welcome to OCC......
These are two conditions we commonly see. (A) Have the Carb cleaned and rebuilt. And, (B), look at the Fuel Pump to see if the internal diaphragm is cracked or broken.
Old 03-09-2016, 09:31 AM
SGragg SGragg is offline
Inactive Member
Welcome to the forum.
Also use Search feature; several threads on the topic of gas in the crankcase.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 03-09-2016, 10:40 AM
john hall's Avatar
Good reason to check the oil every time before you crank it. If it looks slightly fuller than the last time, check for gas. Assuming you still have the KT17 engine be advised that those engines had a nasty habit of getting gas in the oil while sitting under the shed when they were brand new.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-09-2016, 12:56 PM
Thanks for the replies. I will check it out later when I get home
Old 03-09-2016, 08:56 PM
longislandcubs longislandcubs is offline
I have a IH 782 and it had similar issues with fuel in the head and it turned out to be the fuel pump.
