Old 03-13-2016, 08:38 PM
Pro1be Pro1be is offline
Default 2000 Series Tiller
I picked up a 190-304-100 tiller off Craigslist this weekend. Did not really need it but it was close by and the price was right. The PO cut the wiring harness and the belt. Ordered a new belt. Will make a wiring harness. It did not include the lift bracket that attaches the electric lift to the rear of the tractor. However, a couple hours with a band saw, drill press and welder solved that problem. The electric lift works fine after sitting outside for months if not years. The pictures show it "as is" when I got it home. Its installed on a 2185 now. No pictures of the install, yet.
100 w/lights, creeper, rear lift, spring assist & wheel weights, deck is at the powdercoater
1440 w/48" deck
Old 03-16-2016, 08:36 AM
mike.beccue mike.beccue is offline
Nice find! My dad had a 304 tiller on his 2000 series and loved it. I would check your gear box on the side. Sometime depending on use they go bad and u won't keep the chain on. Don't get to invested in it before checking that out before u invest in an expensive belt.
Old 03-17-2016, 09:55 PM
Thanks for the heads-up on the gear box. I ordered a cheap belt to get it turning. As you say, the good belts are $110 to $120. Based on the amount of paint remaining on the tines, I do not think it has seen much use. I have the electric lift wired-up and working.
1440 w/48" deck
