Old 08-15-2025, 03:07 PM
maddog12 maddog12 is offline
Default no spark
i have a 64 model 70 with a kohler k161s engine i cant get spart at the spark plug everything is new coil points condenser plug plug wire have power in to the coil and out to points sometimes the coil gets hot
Old 08-15-2025, 05:58 PM
green407's Avatar
green407 green407 is offline
What's the point gap? Are your points even opening and closing as the engine turns over?
128 X 2, 129, 149, 1250, 1450 x 2
Old 08-15-2025, 09:03 PM
Default spark
yes the gap is .020
Old 08-16-2025, 08:24 AM
green407's Avatar
If you put an old incandescent test light on the points side of the coil and crank the engine, does the light flash?
If the light flashes, then your problem is on the high tension side between the coil and the spark plug.
If the light doesn't flash, then your problem is between the coil and the points ground. A few months back another member had the same no spark situation, they found that there new points were defective.
Old 08-17-2025, 01:11 PM
Default spark
yes it took 2 sets of points for a good one bad batch? thanks very much for tour help
Old 08-18-2025, 06:38 PM
I always clean new points with little brakee clean to remove oil on the contacts. They put it on at the factory...
