Old 05-07-2016, 07:33 PM
RLause's Avatar
RLause RLause is offline
Default M20 Sticky throttle
I have a M20 with a Walbro carburetor that runs like a champ except the throttle valve sticks at idle when the engine is running. The governor is working like it should, but don't have the strength to move the throttle. Stop the engine and the throttle is free as a breeze. It seems like the vacuum makes it stick. In 65 years, I have never seen this before. Anyone have any ideas how to fix it?
Richard
Old 05-07-2016, 08:44 PM
I don't understand what you mean by the governor doesn't have the strength to move the throttle? When it's at idle, the governor is basically relaxed and holding it at idle. When you move the throttle on the dash, are you saying that it won't move off of idle? I just don't know what you mean....
Is this an adjustable Walbro? If so, maybe you have the low idle screw, not the fuel screw, the throttle stop set too low. If you do, the butterfly will stick in the throat of the carb. It needs to be setting on the screw. If it's a non-adjustable, it will still have a throttle stop screw to set idle. If you are sure that is not the case, then you likely just need to clean the carb. I would think the linkage is far more likely to bind that the carb throat being so dirty it sticks. I'd check the stop screw.
Old 05-09-2016, 04:43 PM
RLause's Avatar
Hi Jon, I'll try to explain the situation better. It is a Walbro with adj. idle jet, idle speed is set at about 1200 rpm. Start the engine, throttle up to 3000 rpm, back the throttle down and about 2000 rpm is where the throttle stops unless you take your finger and push it against the stop screw. I disconnected the governor linkage, held my finger on the throttle keeping it closed and started the engine. I can move the throttle and it stays where I put it. It feels like it has Locktite in the bearing. Stop the engine and it free. The manifold gets very cold when it is running. In my 65 years of working on engines, I haven't seen anything like it.
Richard
Old 05-09-2016, 05:06 PM
So, if the engine is off, the throttle moves freely from idle to WOT?
3000 RPM is too low for high idle no load. Should be at least 3600. I prefer to see 3600 with a deck on (engine under slight load). Ok, that's a lie, I set my engines to 3800, but whatever.
1200 is about right for low idle.
Normal for an air intake to get cold.... nothing new there.
If the throttle plate is free with the engine off, sounds to me like you need to adjust the governor.
Old 05-09-2016, 05:46 PM
RLause's Avatar
Throttle is free with the engine off but as soon as it starts it does the sticky thing. The governor is not binding in any way and is set up per the manual. 3000 rpm was not the max governed rpm, it was just a guess as to the speed when I blipped the throttle.
Richard
Old 05-09-2016, 05:49 PM
Adjust the throttle linkage then.
If the throttle plate is free when it's off, it should be free when it's running. Has to be an adjustment that isn't right.
Old 05-09-2016, 06:40 PM
Terry C's Avatar
Terry C Terry C is offline
Are you sure the gov is working properly? Those engines are known
to gernade the gov and put holes in the block.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-09-2016, 07:50 PM
RLause's Avatar
I've installed a new governor and it is working like it should. The throttle butterfly just sticks when the engine is running.
Richard
Old 05-09-2016, 08:00 PM
So.... if you unhook the governor, using your hand to operate the throttle, being careful not to overrev it, it still sticks when running?
Did you try freeing it up? A little WD on the shaft to see if it helps? Anything? Maybe it's just a little "sticky"? All else fails, take the carb apart.
Old 05-09-2016, 09:18 PM
RLause's Avatar
It still sticks with the governor disconnected. I thought about spraying some WD-40 on it but the engine has 800 hours on it so it should be wore in by now. Tomorrow I'll take it off and try to determine why it sticks and lube it up.
Richard
