Old 05-16-2010, 08:13 PM
IanC's Avatar
IanC IanC is offline
Default 149 woes
I just got my 149 back together after a catastrophic bolt breakage on the hydro. I ended up replacing the driveshaft, the coupler on the rear of the motor, the rag-joint and various other bits and pieces.
One problem I'm having is the pin the goes in the driveshaft at the motor. While I was mowing today, it fell out three times. Luckily I found it each time. Now, this is the correct pin that I had to hammer in. I don't understand why it won't stay put. Any hints or ideas to making it stay?
The other problem I'm having is more motor related. I can open the motor wide open and engage the blades. As soon as I start rolling and mowing, the motor loses rpm's. It doesn't feel like the motor is being lugged or bogged down, just that it simply loses rpm's. I readjusted the carb per the manual procedure w/out much improvement. Could this be a symptom of compression loss? Caked up valves? Headgasket? Points? Sorry for being so long winded.
Thanks,
Ian
Old 05-16-2010, 08:42 PM
If the pin is falling out, I think the driveshaft might be worn. You can put a hose clamp around it to hold it in, but I've had those fall off too.
If the engine is loosing RPM, it's bogging down. Does it start hard? It sounds like the timing is off. I just posted a how-to on static timing in the tech library section.
Old 05-16-2010, 08:56 PM
jfinney's Avatar
jfinney jfinney is offline
I just replaced the couple on my 149. The driveshaft is wallowed out, so there is still some slop in it. It either needs a new driveshaft or the old one welded up. Good luck with yours.
Jason
Old 05-16-2010, 09:15 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Thanks,
Ian
You might try some 'Bearing Mount' made by Loctite, it is used to 'glue' loose bearing cups in. Just put some on the pin and drive it in.
Pat Benner Haskell OK
Old 05-16-2010, 09:25 PM
IanC's Avatar
Thanks for the quick replies.
The driveshaft is brand new from one of the vendors here, so I don't think it's already wallowed out.
The mower does seem like it starts a little hard. I'll check out your write up on the static timing(MattG).
Ian
CC 125
1980 Scout II
1973 IH Travelette 1210(3/4ton)
Old 05-16-2010, 09:36 PM
You might try this for a pin from McMaster-Carr: 98400A268 Unfortunately, you probably don't need 10 of them...
Old 05-16-2010, 09:47 PM
chris chris is offline
how putting a bolt thru where the pin goes? i would check the points gap if the motor is bogging down under a load, could also be an exhaust valve
Chris Westfall - Cub Cadet Classics
Old 05-16-2010, 10:32 PM
ihnick's Avatar
ihnick ihnick is offline
i dont understand how cubs can start hard. all my tractors barely turn over and there started. even after sitting for a couple weeks
Nick.
Old 05-16-2010, 10:37 PM
They do if the timing is off. Just because YOUR tractors start easily doesn't mean everyone's do.
Old 05-23-2010, 08:44 PM
IanC's Avatar
Just to update
First: I tried another brand new pin in the brand new driveshaft through the brand new coupler and it still fell out. I ended up putting a bolt in there. I hated to do that, but I needed it to mow.
Second: I was never able to find my timing marks. I looked through the half-moon hole on the right side by the s/g and never saw it. I bet I spun the motor 5 times looking for them. I did check the gap on the points and opened them up to .020. I also put in a new Autolite plug w/ a new plug wire.
Whatever I did made a difference. I was actually able to mow this afternoon without a hitch.
Thanks as usual for all the help.
Ian
CC 125
1980 Scout II
