Old 03-20-2016, 06:52 PM
TIMCRUTCHER TIMCRUTCHER is offline
Default Seats??
Might be a stupid question, but why do most pullers not have a seat?
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 03-20-2016, 07:02 PM
When pulling, your front end doesn't touch the ground. The tractor is small enough you can steer by shifting your behind from side to side. Easier to do on a metal plate than on a seat.
Old 03-20-2016, 07:08 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
weight. the average seat is 15 to 20 lbs. a piece of aluminum is 1 or 2 lbs. most place's will require a 3 in back. and another benefit is being able to move around easier.
Old 04-22-2016, 05:49 AM
Daniel_110 Daniel_110 is offline
Don't you want weight on the rear axle though?? I thought the more the merry in the rear.
Old 04-22-2016, 07:21 AM
dvogtvpe's Avatar
yes and no. moveable weight , tractor weight and low center of gravity have to be considered. if you have a 60 lb driver then weight isn't that important. but its a heck of a lot easier to slide your butt on a aluminum seat than try to do it on a padded seat.
Old 04-22-2016, 08:37 AM
There was a tractor for sale in the local paper some years ago,
it said no seat, no steering wheel.
Was for a fellow who lost his ass,
and didn't know which way to turn.
Old 04-22-2016, 10:53 AM
Terry C's Avatar
Terry C Terry C is offline
You crack me up
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
