Hi everyone just inherited a 1220 with a briggs & stratton. Transmission is jammed in reverse and engine isn't getting any fuel pretty sure the vacum pump is the problem with fuel but any advice on a proceedure on freeing up the transmission.
Cheers Mic. |
Mic:
First, welcome to OCC....... ![]() There are a few of your fellow Mates that are members here too. The 1220 came in two editions, early & late. It depends on the Serial Number range. The 1220 has a Hydrostatic Transmission. As an educated guess, I am thinking the linkage is stuck and needs to be freed up. You can click on this link.... Manuals Type in 1220 for your model, and use "1" as the serial number. Then click on the "search" tab. It will bring up the Owners and Service Manuals for the 1220. For Parts Lookup..........click on this link.... Parts First select Cub Cadet as the Brand. Then type in 1220. Two options pop up, depending on your serial number. Select the one that fits. This is the whole parts breakdown for your tractor, along with all suitable attachments.
Cool thanks for the info, my tractor is probably the early one serial no starts with a 124.
The linkage below the transmission seems to be moving as i move the forward and reverse lever but the transmission doesn't want to go into neutral. Thanks again Mic. |
![]() Quote:
Hi guys any other thoughts on loosening up that hydro transmission without having to totally remove it and disassemble it. Cheers Mic
