I know this is not a Cub Cadet, but have found good help here before:
Working on a Kohler engine on a piece of machinery and do not have spark to motor. 12 V going into coil 12 V coming out of Coyle but no spark at plug? What am I not seeing? Could cool be bad? Brian |
Just checked ohms across the + and - terminal on coiland reads 3.5.
Going to assume coill is good |
And what engine are you working on? Also not trying to be rude but I suggest that you use spell checker.
![]() Quote:
If you have neither, you likely have a dirty set of points or point not breaking the circuit. |
This should help you out.... Kohler K Series Coil
![]() Quote:
Oz |
Fellas,
Filed the points and that worked... Oddly enough, I had this engine running in December and put new points in it so I did not think they were the culprit... THANKS SO MUCH!!!!! Brian |
