Old 03-01-2017, 08:51 AM
ambrola's Avatar
ambrola ambrola is offline
Default KwikWay Loader
What about this one? Looks like you could make a nice one out of this. But I want to put it on a Original, and it's 36 inches wide. Would fit my 124 without much work?
Old 03-01-2017, 10:15 AM
You would have to build a whole different subframe if you buy that one.
What do you want a loader for Ronnie? They aren't really very practical on a GT.
Old 03-01-2017, 11:01 AM
The 124 is a much better option for a loader than an original, the frame on the O isn't full length and cracking where it bolts to the rearend is a common issue.
Old 03-01-2017, 11:08 AM
X2! Without a loader on it....
I'm not a fan of loaders on GT's. They just aren't made for it. The only GT that was that I can think of that was heavy enough, was the JD 318. JD thought so much of that GT that they designed and sold a loader for it. No one else did. That's why all the loaders are aftermarket. SGT's are built more suited to loaders.
Old 03-01-2017, 11:05 AM
ambrola's Avatar
I would like to have one just to use around the yard, I have crushed red brick around the pool and every year I pay a buddy to come over with his tractor to dump it over the fence. It would come in handy with things like mulch. I have a bunch of landscaping to keep up with aas this pic will show, and that's just the pool. Is the Danco the only one that fits an Original? I thought the KwikWay would work on the 124 but they are both narrow frames. Guess that means their the same? I have searched the country for a Danco loader but those who have them, keep them.
Old 03-01-2017, 11:11 AM
Save yourself the heartache when you find out the loaders on the Cub aren't going to do what you want. Get yourself a BX Kubota or something similar.
I believe it is (Danco the only one to fit an O). A 124 and an O are not the same frame. They are both NF's....kind of. The O is basically all it's own. It is the same width, but it has a completely different frame.
Old 03-01-2017, 12:43 PM
ambrola's Avatar
I agree. The Original is just to small or weak in the frame dept. Maybe I'll just save my $ and get the compressor I want. I need to get another buddy over to trim the Lelands. They are 50 of them, and were only around 8 feet when I planted them. Now their probally 25ft? But then I will have to keep on shoveling.
Old 03-02-2017, 01:15 AM
With a yard like that, doesn't the gardener take care of those chores? Maybe you could talk the pool boy into it Ronnie.
