Hi, I have heard about 1 (or 3/4 possibly) in spindles and wondered what cub they are on, would they fit a 149? If it works, does it increase the max capasity of weight much?
Thanks
Clay 149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart ![]()
You will find the 1" spindles on the 82 series on up, i would assume they will take more weight since the bearing is also bigger but how much i'm really not sure. If you're interested in some shoot me a pm.
I have 1" spindles on my 129. They came off of a late production 1650. You'll also need the wheels to go with them.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
The Steering Spindles (knuckle) used on Cub Cadets breakdown as this:
* 3/4" used from S/N: 501 to 632501 (Mid Quietline Production) * 1" used from S/N: 632502 and greater
Ok, I now understand this. Could I just get a different wheel bearings, or would I have to get a different rim?
Clay,
if your using the unit for normal duties a 3/4" spindle will work fine. They went to the 1" for improved bearing life and thrower duty. A lot of those things are still working with factory bearings on 3/4 axles. if it were mine I'd leave it alone unless the axles are worn or bearings wallowed out in the wheels. Then look for the 1" setup. Now if a feller was ah gonna hang a loader on the thing, a 1" setup would be needed.
I can't agree more with the above! There is a Cub Cadet 1" front rim, and respected inner and outer rim bearing numbers listed in my 1450 adventure thread should you go this rout.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
