Deck started making some noise last weekend while mowing- its been raining since, and the sun came out so tried to get another mow in before I pulled deck for new belts and grease.
Got half done- but did notice some smoke when I backed up, and some smell. I didn't smell like a belt burning but... ...why YES those are ball bearings on top of the deck, and yes my main pto pulley on deck is wobbling! I assume I get to use my snap ring pliers to start, but what am I in for the rest of the way? Thanks Chris |
Take the bolt out in the center, remove the old dead bearings and replace them , no big deal. Just a FYI the bearings fit sloppy in the pulley, ask me how I know.
![]() Bearing number is 741-1122 it calls for 2 of them. Link to the Cub parts site. http://www.cubcadet.com/equipment/AR...A/769048060004
Thank You Sam! The 1st thing I saw down that hole was the snap ring. I'll pull apart tomorrow!
Many Thanks Chris |
OP: What size deck do you have? I do have a parts deck so maybe we can get something worked out to help you out if needed
-Ryan
If the bearings are being replaced, make sure to stake the ridge of the pulley just above the bearing to keep it in place after installation. I saw a lot of Cubs come into the shop for belts and bearings that just needed the pulley staked with a cold chisel or punch a few times around the bearing race.
http://www.solunagarage.com |
