Another RPM issue. Seems like something fell out of adjustment. I mowed half of the lawn and after a break I went to start it up and it sounded like it was at about 1/2 throttle.
I tried playing with the throttle adjustment bolt (not sure of the official name for that but it's the adjustable bolt shown in this pic) to no avail. If I grab the governor arm that has with multiple spring holes and manually pull on it slowly, it seems to rev up fine. Could anyone give me any pointers on what else I might try adjusting?
It looks like your "throttle adjustment bolt" is backed off way too much.
Check out my recent thread for some possible tips and pointers. Also, word of caution: consult your owners manual and the engine technical manual before making any adjustments! That little bolt you are tinkering with can mean the difference between a 1000 max rpm and 5000 max rpm thus an exploding engine. Your best bet to get it right on since you've adjusted it thus far is to get a digital tach gauge and set it from there. http://www.onlycubcadets.net/forum/s...ad.php?t=48993
-Ryan
Hmm.
I tried screwing it in but didn't seem to make a difference, maybe I didn't tighten it in enough. I will check it out tomorrow. Thanks. |
-Ryan
Looks like the throttle cable slipped in it's clamp and it won't allow the throttle to go wide open.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
![]() However, if he did adjust his high rpm bolt there, he's probably going to have to re-adjust it again
-Ryan
