Tractor has been running fine but I noticed an oil spot on the drive under the front of engine. I had a job for the tractor a couple of days ago and topped off the gas tank before hand. Next I know there is liquid coming out (dripping) from several places under the engine. This engine has a fuel solenoid so do I have a leaking diaphram in the overhead fuel pump? After the leaking I checked the oil level and it was overfull and smelled of gasoline. What do I check, how do I fix this? TIA Steve
Most likely the fuel pump.
Pull the vacuum hose off and see if it has gasoline in it. |
![]() Quote:
I assumed this engine has a mechanical actuated fuel pump, don't know for sure. Anyway I hope there is a diapharm kit available. I have new fuel line and filter to install. Maybe this is the time to replace the rubber tank gromet. I need a new fuel shutoff valve too, the multi turn valve at the tank bottom does not close (leaks thru when turned in tight). I'd like a 1/4 turn valve close to the filter up on the topside of the engine so I can put the side tins on and still be able to turn the fuel, on and off. Can anybody recommend a good 1/4 turn valve? I have read that some plastic valves are not suitable for today's fuel options. |
I think J-mech means the hose that comes into the bottom of the air filter housing. I have this setup on all my Cubs. Sorry I didn't catch it was Command.
No he means the one coming out the side of the block by the regulator/rectumfire. Commands have that setup, some later mag 18's have it where the fuel pump is mounted remotely on the engine firewall.
![]() Quote:
![]() Quote:
There is a kit, but a new pump is also available and much less of a pain to fix by just replacing it. But a diaphragm kit is available. Quote:
![]() Quote:
The mechanical type is on your valve cover. One fuel hose in, one fuel hose out. It uses rocker arm movement to pump fuel. The pulse type has a fuel in, a fuel out, and a third hose going into the block. That line provides pressure pulses from the crankcase to work a diaphram to pump fuel. I don't believe there is a kit for the mechanical. |
![]() Quote:
clay1811/44c That is what I want, a quarter turn valve and filter near the top of the engine just ahead of the fuel pump. Can you recommend the valve you're using and where/who it came from. Thank you both for your help, Steve |
![]() Quote:
As far as the fuel solenoid goes, it does not actually shut off gas into the carb when the key is off. What it does when the key is turned off is block gas in the bowl from going up into the main jet. The purpose is to prevent dieseling or backfire when you shut the engine down. So realistically gas can still flow into the carb. The scenario of fuel passing through the carb would more likely be because of float/inlet needle issues. But I agree, pump or carb. p.s. the 1/4 turn valve in clay1811's picture can be bought almost anywhere, hardware stores, lawn & garden stores, eBay, etc. About 4 to 5 $. |
