Old 11-20-2015, 06:22 PM
Nightow1 Nightow1 is offline
Default Cyclops plastic painting/finishing
I know someone out there has figured out a good method or type of paint to get the plastic back to a deceit looking finish. starting on Rescue11's 1864, and trying to figure out what to do about his plastic. it's all in good condition but just plain ugly..... is there a buffing process or painting or WHAT????
Old 11-20-2015, 07:15 PM
if you want to try buffing it i suggest wet sanding it with 2000 grit and then using a buffer on it, it may or may not work depending on the condition of the plastic. if you want to paint it i suggest scuffing it with a red scuff pad and then wash it with hot water and dawn dish soap, this will help remove the mold release agent thats in the plastic and is the reason its so hard to get paint to stick. once its washed use an adhesion promoter( heres what i use with excellent results http://www.amazon.com/Kleanstrip-ETP...esion+promoter) and follow it up with your paint of choice.
Old 11-20-2015, 07:36 PM
I used rubbing compound,the red stuff,on a few I had and it came out great,deep scratches will not go away.
Up to 534 and counting...
Old 11-21-2015, 05:23 AM
MWShaw's Avatar
MWShaw MWShaw is offline
I use Bulldog adhesion promoter on all jobs I do. So many car and truck parts are plastic now, you have too.
What this video;
https://youtu.be/sdQy_dfZM84
Old 11-21-2015, 05:25 AM
MWShaw's Avatar
What he said /\ /\ /\
Old 11-21-2015, 08:07 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Buffing with a heavy cutting compound and following up with lighter polishing compound yields excellent results. The more steps you use the better it will look..
There is a very good post on here from member ccguy about restoring the plastic.. His 1440 looks like new.
The plastic on my 1782 was solid but ugly.. It was dull and discolored.
20 min with several different compounds, a foam pad and a buffer have the hood looking like new!
good luck with it
Jay
Proud owner of the following:
Old 11-22-2015, 05:48 AM
good luck with it
http://www.onlycubcadets.net/forum/s...hlight=plastic
Old 11-24-2015, 07:02 AM
drcjv's Avatar
drcjv drcjv is offline
I just did a set of side panels and a hood.
Step 1. Brillo or S.O.S pad
Step 2. Maguires # 49 Marine/RV oxidation remover
Step 3. Maguires # 45 Marine/RV polish
Step 4. Maguires # 56 Marine/RV wax
All three maguires products come together in a kit. I use a high speed rotary buffer for # 49, and 45. Wax is done by hand.
They come out looking new.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 02-02-2018, 10:55 PM
jaynjeep's Avatar
There are several ways to restore the plastic..
CCGUY did a really good job on a 1440 several years ago..
He outlines his procedure in post 23 of this thread
http://www.onlycubcadets.net/forum/s...plastic&page=3
Jay
