Old 09-14-2017, 11:00 AM
cub1810 cub1810 is offline
Default Hi from central IL
I had my first new Cub in about 1963 or 1964. It was a Cub 100 for mowing. Eventually we put a single stage snow blower and creeper drive on it. I've had a few others since then. My current model is an 1810. I'm looking for some help with it. It sat in a shed over the summer and mice built a nest in the right side in the engine cooling shroud. Now it won't get a spark. I replaced the ignition switch, I've pulled the yellow wire to the magneto as well as checked for resistance and had 40,000. I suspect the mice may have eaten the spark plug wires while nesting. Any suggestions would be welcome. I'm getting a bit too old to want to pull the engine.
Old 09-14-2017, 12:30 PM
First, welcome to OCC.......
I think you are right. There is something in this area that is not right. I would suggest pulling the shrouds and do an examination, cleaning, and checking the Ignition Modules. You can do this in the tractor, but it is way easier when the engine is on the service bench.
Old 09-14-2017, 09:39 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Welcome to the club.
Old 09-15-2017, 12:53 AM
Yes, Welcome to the forum.
As Roland suggested, would be your first move...
Old 09-16-2017, 11:38 PM
mhasewinkle's Avatar
mhasewinkle mhasewinkle is offline
Mike
70, 71, 72, 73, 100, 102, 125, 124, 128, 147
1200, 560 Farmall, 340 IH, #2 cart
