Old 10-21-2017, 03:49 PM
Default 782 electrical help.
I'm working on this CCC made 782 and I'm having a bit of an issue. The PTO won't engage with the switch but it will if I jump the wires together at the plug on the switch. When the switch is off it has continuity between terminals F and B and when the switch is on it has continuity between A and B. I have two switches here that test out the same which leads me to believe the switch is fine. As I sit here looking at the wiring diagram it almost has to be something to do with the reverse cutout. Any other ideas I should check out?
Old 10-21-2017, 05:41 PM
Seat switch or reverse cut-out, if it has either.
Old 10-21-2017, 05:42 PM
DieselDoctor's Avatar
First let me be clear, I don't advocate by-passing any safety switch on a permanent basis, but ---- You can jump (bypass) each one, one at a time, to see the results and decide if that particular switch is functioning. If you find a bad one, you'll know what to replace. Easy.
Old 10-21-2017, 05:57 PM
That's what i was thinking, the seat switch is already bypassed so i will check on the reverse cutout later.
Old 10-21-2017, 06:06 PM
Tim, do you have the correct switch?
On a CCC 782 you should have continuity on the C & D terminals (red wires) in the "off" position
PTO start -- continuity between B-A-F (black-brown-orange)
PTO on -- B & A (black & brown)
They didn't use the reverse relay on the IH built 782's.
Do you need the schematic?
Old 10-21-2017, 06:13 PM
Tim, I just looked at your other post and with a 712xxx you don't have the reverse relay and the above wiring in my post is not the same.
Continuity as follows
On = B(tan)-A(tan/black)
Off = B(tan)-E(violet) & C(red)-D(orange/black)
Old 10-21-2017, 06:30 PM
Good call, I guess this tractor would have the IH wiring.
Old 10-21-2017, 07:11 PM
Do you have a wiring diagram for your use?
Up to 534 and counting...
Old 10-21-2017, 07:14 PM
Ok, problem solved. Turns out i'm an idiot and didn't check the fuse, both the fuse and the cap were missing so i stole one from a parts tractor and now it works.
Old 10-21-2017, 07:16 PM
That is good to know you are what you say has happened and all is well.
