Old 12-30-2009, 10:59 PM
dieseldog558's Avatar
dieseldog558 dieseldog558 is offline
Default front pto adjustment
is there any way to adjust the front pto without the guage on a 127?
Old 12-30-2009, 11:03 PM
Trial and error....good luck.
Old 12-30-2009, 11:05 PM
you wouldn't happen to have an extra gauge would you Matt?
Old 12-30-2009, 11:07 PM
Unfortunately not...I've only ever bought 1 rebuild kit. I wonder if someone has a drawing of the gauge...?
Old 12-30-2009, 11:09 PM
yeah that would be nice to see the measurements...be easy made wouldn't it
Old 12-30-2009, 11:38 PM
Some may disagree but this is what I do.
1.) Remove the PTO.
2.) Tighten the jamb nuts on the back side a little bit keeping the tension even between the three screws.
3.) Slide the PTO back into its basket do NOT replace set screws.
4.) Clamp some Vice Grips on the drive shaft.
5.) By hand, physically try to turn the PTO.
6.) Check the engage lever to make sure it will release.
Depending on how easy it slips, repeat steps 1, 2, 3, 5, and 6, until it is difficult to make the PTO slip. As long as the tension between the three screws is pretty even, you should be good to go.
Do not forget to replace the set screws after final adjustment has been made.
Old 12-31-2009, 07:20 AM
Here ya go......
Old 01-03-2010, 08:45 PM
Thumbs up
hey thanks for the info. that pic of the gauge really worked,i cut a piece of hard plastic to those specs and made my gauge and it worked great,i will post a pic soon,really thanks alot
Old 01-03-2010, 09:35 PM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
Do you happen to have a drawing of a WF PTO Gauge? Thanks a lot!
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 01-04-2010, 05:33 AM
Mike,are you talking about a wf with an electric pto?.....if so you only need a .010 feeler gauge to adjust it
