Got a friend with a 1282. His PTO clutch quit today. Assuming its nothing simple like a broken wire or bad switch, air gap etc--any repairs that can be done on those? It appears to be the same as the one on a 1810 (I have one that burnt up--hopefully clutch survived). Guess what I'm asking is, if he has power to the clutch (no broken wires) is it just junk and time to swap it out?
You probably need to ohm it out to see if it is fried.
http://www.onlycubcadets.net/forum/showthread.php?t=30
![]() Quote:
Did it work again after it cooled down? Or you tried that, and it still won't go?
Has he noticed before now, has it slipped after it gets hot in thicker grass? That's how mine in the 2372 was. Cold, it would cut, pull like normal, but each time I would get to a part of the lawn where the grass was thicker, it would stop blade rotation. So the next time I mowed, I started where I usually ended, and it worked "good", until it got hot, then it would stop. I would have to wait till the engine was cool to the touch, start the tractor, flip the switch, and away it would go again. Got worse over time, then bought the Xtreme clutch. A+ NO brainer, built like a tank. Installed it on the tractor, and I don't think the original one was very good for years. Cutting shit with this clutch was effortless, seemed like clippings were really flying out that Haban... ![]() https://xtremeope.com/ =
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
