Old 05-07-2018, 01:11 PM
drcjv's Avatar
drcjv drcjv is offline
Default Where is all the oil coming from
I have a 2072 runs and cuts great but has a pretty good oil leak. i can't figure where it is. I pressure washed everything and did not see anything up front I thought front seal. After washing I noticed oil on shrouds and top of motor under the carb. Ill post some pics. When I pulled back shroud over the heads I found a mess. Where do I need to look? One night this week I will try and get my son to pressure wash the back. I need to disconnect the oil lines to get the shroud off. Hard for me right now but I am determined.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 05-07-2018, 01:57 PM
I would bet it's coming from the crank seal. It's an easy job once the engine is removed.
Old 05-07-2018, 02:06 PM
sorner's Avatar
sorner sorner is offline
Looks about like my 1912 I haven't pulled the engine out of yet. Everything is definitely well lubed.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 05-07-2018, 04:08 PM
Yep the seal behind the flywheel is done. She's A No Seal No Mo.
Old 05-07-2018, 09:08 PM
drcjv's Avatar
Sam she sure ain't. What is involved with this fix? Not sure if I'm up to it.
2072 50" deck
Old 05-07-2018, 09:14 PM
You need to pull the engine out and then remove the blower housing and the flywheel, once the flywheel is off you can use a pick and a hammer to put a hole in the seal, you might be able to use the pick to pull the seal out, if not you can thread a screw into the hole and used vise grips to pull it. Installing the new seal will be covered in the service manual.
Old 05-07-2018, 10:02 PM
drcjv's Avatar
Tim not sure I'm up to that right now. If you were closer I'd drop it off and let you pick it out. I might just have to get a case of oil and wait till winter.
2072 50" deck
Old 05-07-2018, 10:17 PM
I'm not sure i would go that route. That looks like a pretty good sized leak and I'd be concerned that the oil is being blown onto the hot muffler, I'd hate to see your tractor burn to the ground over it. Could you switch the deck to another tractor for now so you can take your time repairing it?
Old 05-07-2018, 10:23 PM
Do yourself a favor and don't run it slobbering oil over everything and clogging the fins with debris,causing overheating.
Or worse, it blows the seal out, while mowing and it throws a rod through the block, because it is out of oil.
Your call.
Luck what ever path you choose.
Old 05-07-2018, 10:30 PM
SS5150's Avatar
SS5150 SS5150 is offline
You're going to have to fix it (or have it fixed) before you continue using it. My 1861 lost that seal last summer, and nearly ran the engine dry in about 2 minutes. It was a heck of a mess.
If you have a cherry picker, might be something your son can handle (with your guidance). It isn't a bad job.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
