Old 06-05-2018, 01:04 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Default (Another) Dumb Question
I've read over and over on many different posts about air leaks in your carb or having the wrong carb adjustments making the engine run lean can cause overheating.
The dumb question is, if the tractor seems to be running great, how do you know if it is running lean?
Randy
Old 06-05-2018, 01:07 PM
Pull the spark plug and post a pic of it. Obviously the pic you post need to be of the end that goes in the engine.
Old 06-05-2018, 01:18 PM
cooperino's Avatar
Heres a little chart.
Old 06-05-2018, 01:45 PM
bllwnkl's Avatar
Good one!
Randy
Old 06-05-2018, 01:50 PM
Adjust it until it blows smoke on a quick rev, then back it off just a little. Rich is better than lean on an air cooled motor. Obviously, you don't want it so rich it carbons the combustion chamber with coal black soot... but it needs to be on the rich side.
Old 06-05-2018, 01:51 PM
bllwnkl's Avatar
See, sometimes you just overlook the obvious. I'll pull the spark plug and post a pic of the end that goes into the engine.
Randy
Old 06-05-2018, 01:57 PM
bllwnkl's Avatar
Thanks, that's what I want. It really runs great for 1 3/4 hours solid. Then acts like it's starving for fuel. I've been tweaking a new carburetor.
Randy
Old 06-05-2018, 02:26 PM
bllwnkl's Avatar
Here's the plug. Without cleaning it, the gap is .030.
Randy
Old 06-05-2018, 02:41 PM
Here's some info on reading the spark plug.
http://www.ngksparkplugs.com/about-n...d-a-spark-plug
Old 06-05-2018, 02:47 PM
bllwnkl's Avatar
Thanks, I appreciate it. My spark plug looks normal to me.
Randy
