Old 07-21-2018, 02:13 PM
IHCubCadet147's Avatar
Default Rake does not touch the ground
My rake stays about an inch above the ground. It seems like it should go down a little more. I have it in the bottom hole on the lower bracket. The guy I bought it from said he made the bracket that attaches to the lift, he copied it from another one he has. Do I have something set up wrong, or was the bracket made wrong?
Old 07-21-2018, 02:17 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Is your stop bracket adjusted too high?
Queen Of The Quietlines!
Old 07-21-2018, 02:22 PM
Also, move the lower bracket to the top holes. Looks like you have it in the lower ones.
Old 07-21-2018, 02:27 PM
The stop bracket is as low as it goes.
It is in the lower hole, I will move it up and see if that makes a difference.
Old 07-21-2018, 02:43 PM
What tractor do you have the rake on?
Moving to the upper hole will make a difference.... I'm certain.
Old 07-21-2018, 02:47 PM
I moved it up and now it touches. I thought I tried that before but I guess not.
It's on my 126.
Old 07-21-2018, 02:59 PM
There you go.
