just joined but have been perusing the site for a few weeks now since I purchased a 1971 cub cadet model 109. Love it. Has a Kohler K301 engine in it so basically got transformed into a model 129. Runs great just needs some clean up. The mule drive belt is quite worn and has started jumping off the mover deck fly wheel. the belt on the unit is 1/2 inch by 81 inch but what I have found is that it is supposed to be a 3/8 inch by 80 inch belt. Would that be why it is jumping off? Look forward to restoring this tank.
You don't say what deck you have but yes, it likely takes the 3/8"X80" belt. Need to know what deck you have to be sure though. An incorrect belt can make it jump off the pulleys, yes. So can incorrect mule drive pulleys, incorrect deck adjustment, bent components, and several other things. |
It is 42 inch deck with three blades. No bent components, mule drive pulleys are original and appear to work fine as does the tensioning spring on the one mule drive pulley. Deck does appear to tilt forward somewhat so I am thinking that between the wrong/old belt and the fact the deck is tipped forward a small amount that might be the reason. I will find out this weekend when I can work on it again.
