Old 10-05-2018, 02:32 PM
gscott gscott is offline
Default Cub Cadet 73
Just finished cutting 3 acres thought I would post a pic or 2.
Cub Cadet 73 with a rebuilt:
K341 (16hp)
Creeper Gear
42" deck
Been cutting with it this summer after the winter rebuild.
Running like a champ. Boy, what a difference in my CC71 with the K161.
This thing will not bog down at all...just keeps on chugging along.
Thanks to all on OCC. This was my first ever rebuild and I came here often for info on these awesome tractors.
Old 10-05-2018, 02:49 PM
Good to hear.
Old 10-05-2018, 03:08 PM
Dirty Steve's Avatar
I like the color scheme. Is it a flat black or something else? Big power, creeper gear, and fenders too. Nice.
Old 10-05-2018, 03:12 PM
Terry C's Avatar
Terry C Terry C is offline
That’s a lot of grass to cut. You must like seat time!
I kinda like the color too.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-05-2018, 03:26 PM
I used rustoleum bed liner, after stripping to bare metal. Was really trying to prevent rust for a few years. It actually worked well on the deck as well. On the deck, underside, I used rustoleum Rust Converter...then heavy coat of bed liner. Some were concerned that grass would stick because of the coarse finish of the bed liner. I have not had an issue at all. The grass discharge is actually very good.I will admit that i did did cut and weld new baffles for the deck that turned out well.
Old 10-05-2018, 06:30 PM
I can’t remember if this was asked before. Did you use the k301 blower housing and flywheel to make the 16 fit?
Old 10-05-2018, 06:35 PM
Yes, sir.
K301 blower housing and flywheel.
Cleaned up the head and fins real well for cooling.
I use an air compressor to keep it cleaned up after a day of work.
Synthetic oil....no cooling issues at all.
Old 10-06-2018, 09:01 PM
Nice 73, you have there!
Old 10-07-2018, 08:51 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Glad to see that this project is working out well for you. You built it to be a worker and it sounds like it is. Just wondering if you wear ear muff's or plugs when mowing? That big 16 has to be pretty loud when under load with the straight pipe.
Old 10-07-2018, 12:52 PM
Yes sir, I do wear ear plugs. The K341 does have quite a bark. Need to save that hearing.
