Old 11-26-2018, 06:01 PM
Rocking416's Avatar
Rocking416 Rocking416 is offline
Default Cub Cadet 782D
I have a Cub cadet 782D I need support fan. P/N 759-3201 It is NLA from cub cadet would anyone know where i can get a used or NOS?
Old 11-26-2018, 10:11 PM
The bearings are replaceable if that is what’s wrong.
Old 11-27-2018, 05:38 AM
Rocking416's Avatar
I need the housing. It cracked.
Old 11-27-2018, 07:56 AM
I'd just spin up a new one on the lathe and make or reuse the existing bracket if it looks as pictured.
Old 11-27-2018, 08:29 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I had that housing crack off on my 782D, lucky the fan only made a small impression on the radiator when it went and no holes. There was a service advisory on that part failing and a service kit was put out on it. The new bracket was a one piece cast aluminum part. Have you tried any of the sponsors to see if they have any on hand?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 11-27-2018, 12:31 PM
Twincreek Twincreek is offline
I welded mine. Not pretty and the angle is a little off but it works. I couldn't find one either.
Old 11-27-2018, 01:11 PM
Did you check with the Sponsors listed at the top of the page...???
Old 11-27-2018, 06:24 PM
Rocking416's Avatar
I have emailed all of the sponsors and am awaiting a reply. I wish i did have a lathe
Old 11-27-2018, 08:02 PM
If you strike out, contact "parts by Jeff" @ the top of the page, he might
be able or willing to make it.
Can you snap a couple of pix of it and post??
Old 11-27-2018, 08:16 PM
mortten mortten is offline
Maybe Kubota still has it available.
Doug
QA-36A
42" blade
