Old 04-03-2019, 10:18 PM
sorner's Avatar
sorner sorner is offline
Default 123 hydro linkage tightening?
My 123 has a problem, the speed lever just takes off to full speed, and there’s little to no resistance when moving it. How do I snug that up? I can’t find anything in the manual about it, and I don’t see anything obvious when looking at it.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 04-03-2019, 10:36 PM
sorner's Avatar
Well I pulled the battery and maybe I found it?
If that’s the nut how in the world do I get to it? Remove the steering column?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-03-2019, 10:44 PM
dale c. dale c. is offline
that's the adjustment . I have a short wrench that I use put it on the nut and turn the lever to tighten
Old 04-03-2019, 10:52 PM
sorner's Avatar
Thanks Dale. I managed to wedge my channel locks in there and get enough of it to turn the handle and move the nut. After about 20 tries, and one shaved knuckle, I got it tightened up.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-03-2019, 11:40 PM
A crows foot wrench work well for that. I made my own out of a piece or flat stock.
Old 04-04-2019, 11:28 AM
sorner's Avatar
Thanks. I got it snugged. The spring is pretty much compressed completely to get it stiff enough to stay in place. Is it not a very strong spring or maybe the spring has lost its spring?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-04-2019, 02:39 PM
jzidle jzidle is offline
So tell me, how easy should it be to move the lever? I feel as though mine is quite tight. Takes a fist around the lever and concentration to make sure it goes where I want it to.
Old 04-04-2019, 03:21 PM
sorner's Avatar
Sounds a little too tight if you have to really crank on it. It should be just tight enough to not creep on it's own. Mine would just shoot right up to full speed. Made it difficult for plowing garden...
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-04-2019, 06:14 PM
Ha, yes. Plowing the garden at 8mph sounds very challenging but very video worthy.
Old 04-04-2019, 06:17 PM
Talking
Ya want to see video worthy??!!
Try loading a Case 130, with a hydraulic transmission, on a short tilt bed trailer sometime!!!
