Old 10-25-2018, 09:48 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Default PTO switch
I used Google to find this drawing of the 725-0893 switch that Roland posted.
I'm having trouble getting the starter to engage on my 1863 even with a charged battery. I'm going to try to clean all the connections in the start circuit. I assume that C and D are the start path through the switch. Also, will the switch function with without anything on the F terminal or is it necessary to have power (?) on it to hold the switch on?
Cannon
Old 10-25-2018, 10:05 AM
To start the tractor, the PTO switch must be in the "off" position which makes contacts through C & D.
The "F" terminal is a "temporary" power source to engage the "reverse relay" which will turn the PTO on.
Old 10-25-2018, 06:28 PM
Terry C's Avatar
Terry C Terry C is offline
Try this:
https://www.onlycubcadets.net/forum/...ad.php?t=38545
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-06-2018, 12:30 PM
Cannon51's Avatar
I finely got around to ordering a MM510 wiring kit for the 1863. The threads I have read on this installation always say that #85 is the ground but the package the kit came in shows #86 as the ground. I wired it like the kit said, hit the switch and got a small flash that blew the 15 amp fuse. I didn't have any of the mini fuses so I made a new power wire with a regular size fuse holder and made #85 the ground. It's working now with a 20 amp fuse. I think the kit was only $7 and change so I can't be to critical of it but the wires are small gauge and to long. I shortened the wires and mounted the relay to the shroud bolt behind the starter. I still need to straighten the wires up with some with zip ties but at least I don't have to turn the key 10 times to get the starter to engage. thanks
Cannon
Old 12-06-2018, 01:06 PM
Cannon51's Avatar
Better picture taken with a camera instead of a cheap cell phone. If anyone sees anything obviously wrong let me know. I had to take the relay out in the sun so I could see the numbers and write them bigger on the side.
Cannon
Old 12-07-2018, 11:54 AM
swacor swacor is offline
Cannon
Heres mine the black is ground
