Old 09-05-2019, 12:20 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Default 982 dies after minute run time
My 982 with 18 mag will die after about a minute with mower deck engaged. Shut PTO off and pull choke out and will limp it back to garage. Rebuilt carb last winter. Pulled it off looked good, cleaned all passages. Changed fuel filter. Put new gaskets on manifold. Still have same symptoms. I know pulling choke to keep running is indicative of carb issues, I just don’t see it. On a side note the fuel pump leaked out the other night, I installed a shut off valve and drained the oil/gas. Not sure if the pump could be the culprit?
-Rick
IH 782
IH 126
CCC 1863
Old 09-05-2019, 12:28 PM
cooperino's Avatar
When you changed the oil, Did it smell like gas?? Was the crankcase overfull?
Old 09-05-2019, 12:50 PM
Rmowl's Avatar
Yes, was over full. Changed oil/gas mixture and installed shut off valve
-Rick
IH 782
IH 126
CCC 1863
Old 09-05-2019, 01:12 PM
cooperino's Avatar
Well,
Either your float is not closing the needle, or your fuel pump is leaking into engine.
Old 09-05-2019, 01:33 PM
bill682 bill682 is offline
There is a shut off valve and screen at the bottom of the fuel tank that maybe is clogged.
Old 09-05-2019, 01:51 PM
cooperino's Avatar
The OP is getting too much fuel so much that it is getting into the oil. The fuel valve at tank is not meant keep that from happening. The needle valve in carb controlled by the float is meant to stop flow of fuel when engine is not running.
If that valve is not being closed it means one of the following is happening.
A. Dirt keeping needle from closing
B. float not adjusted correctly
C. hole in float weighing float down keeping needle open.
There are other ways for fuel to get into crankcase. For the OP's sake I hope its the more simple things that I just mentioned.
Old 09-05-2019, 02:14 PM
The original question was shutting off after a minute under load and choke helps to keep running. Indicates fuel restriction.
Side note was about fuel in oil.
Old 09-05-2019, 02:40 PM
ironman's Avatar
ironman ironman is offline
Agreed. I was going to mention checking for a clogged vent hole in the gas cap but now I guess there are bigger fish to fry.
Old 09-05-2019, 02:43 PM
cooperino's Avatar
Yeah.. I understand that. Was luckily able to deduce fuel in oil which is "like Ironman said" Bigger fish to fry.
Old 09-05-2019, 09:54 PM
Rmowl's Avatar
Ditched the walbro carb and rebuilt a kohler/carter carb and installed. Too late to run it under load but engine sounds better wide open. Still have a walbro on a couple rigs that haven’t given any issue yet.
-Rick
IH 782
IH 126
CCC 1863
