Old 09-24-2019, 04:04 PM
Ellebrecht Ellebrecht is offline
Default New member from Indiana cub 149 questions
Hi all.
New member from Indiana. I did introduce myself in the appropriate forum I hope. As I am looking for a 149 with 50" deck I dont know everything possible with them. I know you can put a 3 point hitch on the rear. But is there a rear pto? What about a front pto? Can I add hydraulics to the front and rear? I've seen 1 with a loader and bucket for digging. Is that a complete custom job or is it a kit that can be purchased?
Thanks for any insight
Michael
Old 09-24-2019, 05:37 PM
First, welcome to OCC..........
If you want a item, place an Ad in the Want Ad section describing what you are looking for and give the necessary information.
There was an optional rear PTO. It revolves opposite for normal applications and thus worthless without a "reverser".
All 1x8/9 series tractors had a front PTO.
Although it did not come from the factory with auxiliary outlet(s) for the front/back, with some modifications it could be done.
Front end loaders could be installed. They were made by third party vendors.
Old 09-24-2019, 07:34 PM
Merk Merk is offline
There is a rear pto for a manual transmission IH Cub Cadet. You can use a tiller drive as a rear pto. My Dad has a rear mounted mower that gets it's power from tiller drive.
A loader has its own hydraulic system. The hydraulic system on a IH Cub Cadet doesn't have enough volume or pressure to make a loader preform very well.
IH Cub Cadet made a system that has 2 remotes. There is a front mount blade that has hydraulic tilt and lift. Depending on your fab skills you can add a front and rear remotes.
Project Uncle Dick
Cub Cadet 70
