Old 10-04-2019, 06:44 AM
MrRazz MrRazz is offline
Default Quietline 1250 first post
Hey everyone this is my first post on here.
II recently bought a 1250 with 50" deck and snowblower. I've wanted one for a long time and I finally decided to go for it. Its in decent shape but has a few things I need to work out with it. I will start with two things and as I fix them, I will post some more.
First thing is the PTO doesn't always fully disengage. I've read how to adjust it in the manual but I'm not sure what to exactly gap to .010" through the slot. I don't see a gap I can stick the feeler gauge into. And the second problem is when I leave my tractor parked with the deck raised, it will slowly lower over about two days. It has the hydraulic lift.
Any help would be greatly appreciated.
Thank you.
Old 10-04-2019, 08:04 AM
First, welcome to OCC..........
The Electric PTO issue can be found here........ Elec PTO
You may have a leaking Hydraulic Cylinder, Spool Valve, or Piping issue. You have two options. (A) Tolerate it, or (B) trace the issue down, and get it fixed.
Old 10-04-2019, 08:28 AM
I looked at that diagram as i was checking out my pto but i dont see any gap in there to slide my gauge into. I guess the plate needs to be turned out to open a gap then?
Old 10-04-2019, 08:32 AM
It is normal for the deck to drift down in 1/2 a day.
Nothing to worry about.
All hydraulic systems have a permissible internal leakage.
some are minute, others are allowed more permissible drift.
Welcome!
and you can spend months here reading/getting educated on your GT
Oh,
And the fellers like pictures.
Old 10-04-2019, 08:40 AM
The pto needs to be off (no power applied) and the feeler gauge needs to be inserted between the plate and the coil. (#2 and #3)
Not between the stamped plate and retaining ring/cover where the springs attach, that is a brake and you do not adjust it as it has no clearance with power off, thus in braking mode.
it is automatically set when you adjust the air gap between #2 and #3
Old 10-04-2019, 10:09 AM
ironman's Avatar
ironman ironman is offline
Go by the settings that are stated in the manual, but here is a You Tube video that will give you a good idea of what you have to do.
https://www.youtube.com/watch?v=hZNILWqmcEg
Old 10-04-2019, 10:16 AM
ALL OEM PTO's have that gap slot (3 of them) right near the adjusting nuts. Now unless someone has thrown an off brand, or aftermarket PTO on, the slots are like indicated in the link.
Old 10-04-2019, 10:34 PM
MARK (LI)'s Avatar
MARK (LI) MARK (LI) is offline
[QUOTE=ironman;488902]Go by the settings that are stated in the manual, but here is a You Tube video that will give you a good idea of what you have to do.
https://www.youtube.com/watch?v=hZNILWqmcEg[/QUOTE That is one of the best how to videos out there...right to the point and well explained
Old 10-06-2019, 09:09 PM
I havent been able to look at it since i posted. I blew my back out so if im feeling up to it i will try to take a look at it tomorrow. I can deal with the hydraulic lift lowering over time but i want to address the pto before the snow falls.
Old 10-11-2019, 06:50 AM
Ok so i have the pto adjusted correctly now and it works as it should. Im not sure why it was so much out if adjustment but its all good now. Im going to live with the lift sinking over time, its not really a big deal for me.
