Old 11-05-2019, 09:18 AM
woodbuilderbob woodbuilderbob is offline
Question 102 wont move in gear
New cub cadet owner ...
I have a 102 appears to be all original no creeper. Was working fine driving around the yard hauling firewood. Drove up the sloped curb from the road to lawn and it just stopped moving partly up the incline.
The tractor shifts fine into all four gears and when in neutral it rolls with no issues. The drive shaft is struggling to spin. It spins a little but not consistently when in neutral and does not spin when in gear.
Not sure if I should be looking at the transmission or the clutch.
Thanks.
Old 11-05-2019, 10:24 AM
First, welcome to OCC..........
Your problem sounds like one of the "spirol pins" in the Drive Shaft has broken. I would look at those ----- first.
Old 11-05-2019, 11:00 AM
To get to that I need to remove the fenders and take off the top of the transmission ?
Old 11-05-2019, 11:16 AM
OR....look from underneath.
Old 11-05-2019, 06:34 PM
dale c. dale c. is offline
if the drive shaft is not spinning with it in gear it has to be a pin at the front by the engine. or the clutch is not gripping
Old 11-16-2019, 12:12 AM
Looks like the spirol in is missing from the front disc at the clutch. Just received my replacement part. Any tricks/tips on how to put it in?
Old 11-16-2019, 07:34 AM
Just pound them in.
Old 11-16-2019, 10:05 AM
Did you get a true "spirol pin"?
or a hardware store split pin.
If the latter, it will get you going but probably won't last very long.
Use a pin punch to install it after lining up the slot in the drive plate with hole in the driveshaft.
If the pin slides right through the shaft and falls back out, it's time for a new driveshaft. you could use a small hose clamp to hold it in place or a piece of wire through it and tied but, again, won't stand the test of time and use.
Good luck!
Old 11-16-2019, 12:43 PM
Use of some heat would certainly help, too! Make sure the old pin is completely out and not just sheared off in the old hole. More than likely, it is sheared off. If you don't want to put heat to it, then you can use PB Blaster on it. Soak it in PB Blaster for a day or so before doing work on it. Do NOT use PB Blaster AND heat, as it is flammable! Wear protective eyewear or a face shield.
Old 11-16-2019, 01:29 PM
Aw come on. It makes things "interesting and fun"....
Tags
102, clutch, drive shaft, not driving, not moving
