Old 12-05-2019, 08:49 PM
Trakter26 Trakter26 is offline
Default New Guy Northern Ohio
Planning on buying and rebuilding old school Cub Cadet this winter. They do not last long on CL so I need to act fast when they do appear. I have noticed that these tractors are tough as nails from engine to rear wheels. My main use for this will be mowing and it seems to me the decks do not hold up as well as the tractors and the quality of the cut is not optimal. 1 acre yard, mostly flat. Are those observations accurate? Also, I restored several 60’s cars. Love to drag rust buckets home, spend a year or two on them, sell them for much less than I have in them but loved every minute of working on them. Same virus for Cub’s?
Old 12-05-2019, 10:21 PM
athomas's Avatar
athomas athomas is offline
Welcome to OCC ! You will find a wealth of info here to help you with your first cub, the next couple cubs will get easier ! I like the late 60's early 70's tractors the wide frames from the early 70's are a little easier to work on with the removable tunnel cover but I like the late 60's triangle shaped decks better than the later decks, I just think they cut better ! The thing with the decks is to clean them good at the end of the season ,slap a coat of rustoleum on the underside and keep the baffle/deflector in place on the underside, most of them need replacing and are easily fabbed at home. Some will say the baffle isn't needed but I think it cuts better with it ,just my opinion and I've been running these cubs since the mid 60's ! They are pretty much bulletproof and where built to last a lifetime ! happy cub searching !
Old 12-06-2019, 07:14 AM
First welcome to OCC......
Oh, I don't know if I would agree with that. My 1984 tractor still has the 1984 mower deck on it.
As far as quality of cut, your assessment is correct. They did not have the "high tip speeds" back in the day. IF..........cut quality is a major factor, then buy something new.
Old 12-06-2019, 07:59 AM
cooperino's Avatar
Welcome to OCC!
I will weigh in on the mower deck and cutting.
My 1969 126 with original triangle deck cuts great and has had no rust holes ever. Still extremely solid. The only thing I did was install new baffle which is common on these. Also I replaced blades with good quality American made blades. It cuts extremely well in tall grass to short. As Roland had stated the tip speed on some of the older decks is a bit slower. However, with the short outer blades on the triangle deck and the larger center blade it does really well.
When I am forced to cut in tall wet conditions, My 126 is still my first choice even over my higher horsepower and larger deck machines.
Old 12-06-2019, 12:07 PM
MBY852's Avatar
MBY852 MBY852 is offline
You won't be disappointed with a cub!
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 12-06-2019, 04:53 PM
Looks like mowing decks just need some dialing in for good cutting. I know I have not been keeping up with proper deck adjustments and maintenance on my newer Cub. Thanks for insight.
Old 12-07-2019, 10:56 AM
IHinIN IHinIN is offline
Welcome to OCC. I agree that the square end triangle decks cut nice. The early cast end decks have very short outer blades so the blade tip speed isn’t the greatest. On the 48” triangle deck, the outer blades are nearly the same length as the center blade.
Old 12-07-2019, 07:34 PM
IHCubCadet147's Avatar
Welcome to OCC! I’m sure you won’t be disappointed with a Cub. They are very addictive, 1 will turn into 10 before you know it.
Old 12-15-2019, 07:40 PM
Welcome to OCC!
