Old 04-03-2020, 08:24 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Default 782D advice--- moving engine
I need to remove the driveshaft to replace the hydro fan.
I'm not sure how much clearance I need to accomplish this. I know that there's 4 motor mount bolts....is it possible/likely that if I just remove these bolts and push the engine forward a half inch or so, I'll get enough clearance to remove the shaft?
If so, that's not so bad. If not, well.....
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-03-2020, 09:10 AM
Yup, you can do it that way.
Old 04-03-2020, 09:15 AM
jbrewer's Avatar
Thanks Roland, I'll give it a go!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 04-04-2020, 08:55 AM
John, don't mess with the rubber mounts. The complete engine/radiator assembly will move as one. Just undo the bolts that hold the engine mount to the frame.
Good time to replace the water pump belt and check all the ball bushings too.
Gates belt #
Fan = 6727
Water pump = 7320
Old 04-04-2020, 09:05 AM
jbrewer's Avatar
OK, hopefully I can just slide things forward a half inch or so ... which might be enough to drop the driveshaft?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 04-04-2020, 01:39 PM
jbrewer's Avatar
Default later that day....................................
Well, I tried the 4 rubber motor mount bolts, have the spirol pin out of the rear, the four bolts loose on the front and rear trunions and ....
.... there's not enough room.
I'll now go look and see what's up with removing the four main cradle to frame. I'll go bolt the donuts back to the cradle.
I now remember why I didn't do this job when I bought the fan replacement two years ago!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 04-04-2020, 06:08 PM
jbrewer's Avatar
Took a break.
Ate lunch
Played with the cat.
Went back to work on the diesel. By loosening all the bolts on the front trunions , removing the nuts on the rear , removing the roll pin and loosening the 4 rubber dounts , I was able to scootch the rear of the driveshaft out of the ball bushing (in good shape).
Got the new fan on, left it loose so I could scoot it back and forth while putting everything back together , put in new roll pin (note to self, beveling one end on the grinder and oiling 'em up really lets em go in easy) and safety wired em.
I got almost everything back...need to put the grill and hood back on , (and put new spade lugs on the harness...oops! Forgot to remove one connection on the harness) and double check everything .
A good days work. Those front trunion bolts are fun to get to. I need to order one new trunion and probably a new driveshaft as the front has some slop in it. Tappet wrenches are handy holding some of those front bolt heads!
Thanks for the help. I know how this goes together (and apart) better now.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 04-05-2020, 10:53 AM
jbrewer's Avatar
J
Gates belt #
Fan = 6727
Water pump = 7320
Im going to go order these belts so they'll be ready when I replace that front trunion. Thanks for the numbers!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
