Old 04-19-2023, 11:26 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default Evidence of accident on 70…?
Ever since I bought my IH Cub Cadet 70 there are several things I’ve noticed that are messed up that I’ve been wondering about. They all lead me to believe that the previous owner hit something with the tractor. However, there are no obvious dents that I’ve seen and I don’t have a model 70 or 100 to compare it to. The first thing is the muffler, it’s crushed against the front end section that holds the grill in place. The second thing is the hood, new holes were made in it for the bolts so it wouldn’t be stopped by the steering wheel; if the hood and it’s bolts were in the correct spot the steering wheel would prevent the hood from opening. I’ve included pictures below. Thanks for your time, any input is appreciated.
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 04-20-2023, 10:17 AM
Remove the hood and pull the grill.
Check for bent ears on the bottom of the frame rails.
Holes that secure the grill to the frame may be wallered out and distorted.
Not uncommon on this model of Cub.
Old 04-20-2023, 10:40 AM
LAWN BOY's Avatar
Thanks for the reply. Is there a way to fix it or do most people leave it as is?
Old 04-20-2023, 12:21 PM
ironman's Avatar
ironman ironman is offline
You might be able to loosen the grill shell bolts and slide it forward enough to give space to the muffler.
maybe you got the wrong hood?
Old 04-20-2023, 01:05 PM
LAWN BOY's Avatar
That is a good idea Ironman. I will try that later on. It may look a little distorted after doing that but I'll just have to wait and see. The hood is about 28 3/8” long.
Old 04-20-2023, 02:08 PM
Remove the grill housing and you will see the frame will be bent, flatten it out then add 1 washer under the grill frame on the back two bolts.
