Old 05-22-2020, 01:38 PM
JPMorgan JPMorgan is offline
Default High performance Air Filter Upgrade?
I have a new ZT1 54 Cub Cadet. It came with a Kohler 24 hp KT735.
This Kohler motor has the short, low profile air filter...
In the Kohler booklet I noticed there is a High Performance version of this motor that has a taller air filter.
Does anyone know if the High Performance air filter "cover" will fit/fasten to my existing motor, shorter air filter cover?
If so my plan is to Upgrade the Cover and go with the taller air filter!
Best Regards,
JP
Old 05-25-2020, 01:46 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Cannot help with your air filter question but let you know that the Pro series Kohlers also came with a high performance spark plug (platinum) , oil filter (larger capacity) and fuel filter
The photos of both standard and Pro engines (Horizontal) show the same air filter cover if that is any consolation
Oz
Old 05-25-2020, 09:51 AM
Probably just a foam wrap for the existing filter??
Old 05-25-2020, 10:59 AM
bill682 bill682 is offline
Best Regards,
JP
I believe it will. Read the reviews in this link.
https://www.amazon.com/Kohler-32-096.../dp/B0728CSQGZ
Old 05-26-2020, 12:22 PM
Default Thank you!
I believe this Cover will work too.
Thank You!
regards,
JP
Old 05-27-2020, 01:54 AM
Ozcub's Avatar
If you want to take it up another notch you can buy thick and thin pre-cleaners
Oz
Old 05-31-2020, 11:07 AM
Default good idea!
Oz
I'm also considering placing course foam filter material in the 2 Inlet Holes on the lower filter housing piece...
Old 06-04-2020, 12:24 PM
Default Amazon purchase is a fit!!!
I received the Air Filter Cover yesterday from Amazon and it's a perfect fit to the existing Top plastic Shroud!
So I've now got a Pro Filter set-up! Twice the air intake and filtration!
Nothing wrong with more filtered air.
I'm now considering a course foam material to insert into the 2 intake holes on the bottom filter housing. And maybe introduce a couple of new holes in the new top cover for more air intake and of course place foam filtration to those...
regards,
JP
