Old 07-20-2020, 08:15 PM
Blacksmith Blacksmith is offline
Default 3000 Series serial number location
Bought a 3000 can’t find the serial number. It’s not under the seat or on the frame where I can see it. I was told it is a mid 90s machine. It has a 23 horse Kohler Command, shaft drive, cast iron differential, differential lock. That’s about the extent of what I know about it so far. Would like to have the numbers so I can go shopping for manuals. Any help would be appreciated.
Old 07-20-2020, 09:23 PM
ejl6658 ejl6658 is offline
Model/serial number tag should be on right frame below right side engine bay cover. Based on your info and the attached link for the spec sheets it would have to be a 2001 or 2002 3235.
https://www.cubcadetpartsnmore.com/c...et-spec-sheets
Old 07-20-2020, 09:37 PM
Thanks for the reply. I’ll look again, maybe it’s on the bottom of the frame.
Old 07-21-2020, 06:38 AM
dale c. dale c. is offline
they just had stick on tags which fall off sometimes
Old 07-21-2020, 07:22 AM
I really wasn’t wanting to hear that... lol
Old 07-21-2020, 07:55 PM
I found a sticker on the right rear of the differential.
618-3223
S/N 1B021Q1 0049
Would these numbers pertain to the tractor or just the differential..? Sorry for the dumb questions.
Old 07-21-2020, 08:28 PM
618-3223
S/N 1B021Q1 0049
I would say that you have a 3235 built in 2001.
Old 07-21-2020, 08:57 PM
Thanks very much. Off to find manuals.
