Old 07-07-2020, 09:51 PM
PEACEMAKER322 PEACEMAKER322 is offline
Default Picture
My new 147
Old 07-12-2020, 07:43 PM
Default Model #
I found the serial number but where is the model number?
Old 07-12-2020, 08:17 PM
2050041Uxxxxxx
205 = IH Garden Tractor Code
0041 = Model 147
U = Made is USA
XXXXXX = Sequential Serial Number
Old 07-24-2020, 10:12 PM
Thanks for the breakdown.
Old 07-24-2020, 10:16 PM
Can someone tell me how that small lever below the seat is supposed to disengage the transmission so the tractor can be pushed?
Old 07-25-2020, 06:22 AM
Here ya go...
Old 07-25-2020, 02:27 PM
mortten mortten is offline
There’s a flapper connected to the lever that pushes down on the relief valves. You can pull the cover off and make sure the flapper is still there. They do break off sometimes.
Doug
QA-36A
42" blade
Old 07-25-2020, 03:46 PM
athomas's Avatar
athomas athomas is offline
Not that easy on the narrow frames !!
