Old 01-21-2021, 08:37 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
Default Montgomery Ward Hoe-Trac
Thought I would share a few photos of my non Cub garden tractor. I decoded the engine SN and thought is was a 52 or so. It's called a Montgomery Ward Hoe-Trac. Made by Simplicity. I'm keeping an eye out for a Plow-Trac close by. I'm sure my wife will love it. As you can see i'm in the process of making it electric. I have 2 100ft extension cords. So it currently has a 200ft all electric range. Figuring out exactly what to do with it. Gonna try to plant some sweet corn this spring. It has a sleeve hitch, thinking about getting a brinley cultivator and then I can walk right down the rows. Guess I could set a generator on top of the cultivator. Or go back to gasoline. So much easier to control with electric. Off is off. No slack belt running on a spinning pulley to run away.
Any comments or suggestions or questions are welcome and appreciated.
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 01-22-2021, 08:30 AM
Leadslingingdaddy's Avatar
I would put a Harbor Freight 3hp on it...
Old 01-22-2021, 09:45 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Use the sleeve hitch to tow along batteries
Joking aside, cool machine!
Plow blade
#2 Cart
QA36 snowthower
Old 01-22-2021, 10:09 AM
Cubcadet_107's Avatar
If you weren't so far away I'd take that little Briggs off your hands "so you don't hafta deal with it"
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 01-22-2021, 05:12 PM
MSS7120's Avatar
I did repower it with Harbor Freight. Then I repowered again with electric.
I went with the 6hp as it was cheaper than the 3hp. Also the 3hp had a different bolt pattern on the bottom. I would have had to drill new holes. As it was I lifted it with spacers anyway. The new motor had interference on the back side. I even placed the free light on the gas tank for an impromptu headlight. Just barely enough steel in the gas tank to keep the magnet sticking. I have small kids, with electric the motor stops as opposed to loosing a belt that could catch and walk away on you.
Both wheels have a ratchet mechanism inside the hub. When they both lock up it will pull you away.
Mark from Minnesota
CC yard cart
Old 01-22-2021, 05:27 PM
MSS7120's Avatar
I actually have considered hooking my yard cart to the back side and placing my 4kw generator in the cart and running an extension cord. Got another motor all wired up with a SPST and DPDT switches for on/off and direction control. See photo of my little test bed motor. It really works well.
Mark from Minnesota
CC yard cart
