Old 10-10-2020, 05:46 PM
Workinprogress Workinprogress is offline
Default Cadplan loader build - 1512
Been a busy summer. In the final stage of a loader build for my 1512.
Starting running loader on the tractor hydraulics but just added separate hydraulic system for it. Belt driven pump.
Only remaining it is a skid plate to protect the pump.
1512 with CADloader 507, CADdigger 508 and 3 pt
1711 with KT17
782 with KT17 and 3 pt
104
Old 10-10-2020, 07:10 PM
Just picked up a ton of wood pellets. Was able to test the loader.
I was able to lift 400 lbs (10 bags) with the loader but rear wheels quickly lost traction. Top picture.
Rear tires are loaded and I have 75 lb wheel weights on each side.
Seemed that just under 300 lbs (7 bags) worked well with current tractor setup. Second picture.
Due to bucket size it was tough to even get the 7 bags balanced.
File Type: jpg 03C05765-720A-468B-8521-C5119281A271.jpg (36.6 KB, 220 views)
File Type: jpg 7F8C47CC-5B3A-42AB-B6F2-973BCB4FE394.jpg (39.4 KB, 221 views)
1711 with KT17
104
Old 10-10-2020, 07:24 PM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
That looks great.
I am slowing working on one for my 1863.
I will use a belt or shaft driven pump also.
What pump did you use?
Old 10-10-2020, 07:32 PM
The single arm loader doesn’t require that much hydraulic volume.
I used this pump. This pump is available in multiple sizes but the key feature is the shaft supports a side load (ie belt driven).
https://www.zoro.com/concentric-moto...specifications
I also used the split taper pulley. Really locked well onto the pump shaft.
https://www.surpluscenter.com/Pulleys-V-Belts/
1711 with KT17
104
Old 10-10-2020, 07:39 PM
I see you have upgraded the Front spindles also.
I have the stuff to fix mine also.
Old 10-10-2020, 07:51 PM
I upgraded the front bearings years ago. Actually found the upgrade on ebay.
Works well!
1711 with KT17
104
Old 10-10-2020, 07:56 PM
twoton twoton is offline
Nice job on the loader!
Old 10-10-2020, 08:31 PM
Very nice!
Old 10-11-2020, 07:16 AM
bugeye bugeye is offline
Looks great. Being in Vermont, maybe get get some snow removal duty.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 10-11-2020, 09:04 AM
Thanks! Yes this should be nice for snow removal.
While this one is almost done my project list continue to grow.
Bring a 104 back to life. K241 kohler is at machine shop.
Modify trailer to have hydraulic dump.
Thinking about small logging winch out of scrap parts I have.
1711 with KT17
104
