The ole machine is not running as it should and I would like to try carb adjustments. It need to be choked to run properly. Does anyone have instructions for carb adjustments? Thanks!!!
It does not need adjustment. It needs to be removed and cleaned. Probably the whole fuel system needs to be gone through. New lines, filters, etc.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
The Walbro carb has WHG601660 stamped on it but I am unable to locate a carb repair kit using that number. Machine SN is 815597. Got any leads
??? Thanks. |
Go here https://cubcadets.s3.us-east-2.amazo...+TP-2377-E.pdf and the part number for the kit will be in there.
Thanks for the support....the carb has been cleaned, the kit installed and adjusted per the manual. The high idle adjustment has no basis on how the engine runs but the low one does. Thats kinda weird!!!! It seems to run ok just set at 2 turns out.
